Export Flat Sheet Metal Cut Sheet to DXF for use in laser cutting
scott_stapscott_stap Member Posts: 2
I am looking to export the flat sheet metal drawing as a DXF image.  I need this for the laser cutter program to cut my part.
Either I am missing how to do this or....
  • Jake_RosenfeldJake_Rosenfeld Moderator, Onshape Employees, Developers Posts: 1,646
    Scott,
    If you right click on the flat pattern you can select 'Create Drawing of Flat Pattern' to create a drawing, and then export the drawing as a DXF.
    If you would like to be able to directly export the flat pattern as a DXF I suggest you raise an improvement request to the right -->
