Extrude-remove doesn't works with sheet-metal part
konstantin_shiriazdanovkonstantin_shiriazdanov Member Posts: 1,221 ✭✭✭✭✭
faced some kind of a bug, or strange behavior of extrude-remove to sheet metal part - i can make single-side remove, but can not perform it reversed or in two directions
https://cad.onshape.com/documents/63d94a5e9e06911d2cbe75a1/w/f342e2181ffb1d646da0395f/e/efd70c7f949093adab76e6d3
    Hello,
    This seems like a bug, please file a support ticket by clicking the 'feedback' option under the '?' menu in your document.
  • lanalana Onshape Employees Posts: 761 image
    This very much looks like a bug. I could not come up with a work-around for it either. Will investigate further. Thank you for raising this case.
    i made a bug-report about this case, and about not working corner relief adjustment for that part
