Needing help splitting a part
aaron_skidmore
Member Posts: 34 ✭✭
I am trying to split this part in 3 'pie' section, but when I use spit part with plane it cuts it in half.
Any ideas?
Any ideas?
You can extrude the lines to make a surface and then split using these but it still takes a few step to the get the result.
see doc here https://cad.onshape.com/documents/00953f5f3cac0377ca28f387/w/a5c76e5cdca2620bd2edf3e7/e/46841821634c712e88b82c84
7
7 -
A plane goes off into infinity in all directions other than those directions normal to the plane0
Un saludo,
Partner de PTC - Onshape Averigua a quién conocemos en común2
