Sheet Metal
Jay_Jeffs
Jay_Jeffs Member Posts: 1 PRO
edited March 2017 in Community Support
Hey, first time visitor and post to the forum. I asked a question in the webinar but I understand it is a bit hard without visual aid, so hope we can figure this out here. When using the Flange and Move Face commands an error occurs. In example one you see that the flat is changed and the line doesn't stay straight, it gets changed to an angle. Anyone else facing this problem?
My second question is this one, I am trying to add a tab to my Sheet Metal Part. It goes on the same line as the Flange and Move Face command, I cannot make it appear on the flat. When exporting to the press brake it doesn't place the tools correctly and ends up bending the flange or I have to move the tools set up to avoid it.
  • Ben_Misegades
    Ben_Misegades Member Posts: 133 ✭✭✭
    Not sure about the first question, but for the second thing, "tab" creation as it were isn't supported in OS right now, at least not how it works in something like Solidworks. In your feature tree, anything you add to the sheetmetal component after "FINISH SHEETMETAL" gets ignored in the flat, so you have to figure out a way to add that tab prior to that.
  • john_doubleday
    john_doubleday Member Posts: 58 ✭✭
    EXCELLENT TUTORIALS...thanks muchly :)
