Problem using opExtrude in functions
frank_halma
Member, Developers Posts: 2 ✭
I am trying to make some functions for creating extrusions. Unfortunately I cannot get things work.
When I use only 1 function, it works prefectly. Also when I disable the opExtrude, the sketches are made as I expected.
When I don't use functions I don't have any problems.
I am pretty new in FeatureScript, so probably I miss something easy...
Below the (simplified) script I tried.
Thanks a lot for helping me out!
Frank
Frank
FeatureScript 531;
import(path : "onshape/std/geometry.fs", version : "531.0");
const __BOOLEAN = "boolean";
const __DELETE = "delete";
const __EXTRUDE = "extrude";
const __PLANE = "plane";
const __POLYLINE = "polyline";
const __RECTANGLE = "rectangle";
const __REVOLVE = "revolve";
const __SKETCH = "sketch";
const __ZEROMM = 0 * millimeter;
annotation { "Feature Type Name" : "PARO002" }
export const myFeature = defineFeature(function(context is Context, id is Id, definition is map)
precondition
// Define the parameters of the feature type
var XMax = 300 * millimeter;
var YMax = 200 * millimeter;
var ZMax = 100 * millimeter;
var index = 0;
// Disable MB = makes CC = work
var MB = createMainBody(context, id, index, XMax, YMax, ZMax);
index = index + 1;
// Disanle CC = makes MB = work
var CC = createCutOut(context, id, index, XMax, YMax, ZMax, 2, 0 * millimeter, 0 * millimeter, 30 * millimeter, 20 * millimeter, 0.75 * YMax);
index = index + 1;
function createsketchPlane(context is Context, XMax, YMax, ZMax is ValueWithUnits, Face is number)
if (Face == 1)
return plane(vector(__ZEROMM, __ZEROMM, ZMax), vector(0, 0, 1), vector(1, 0, 0));
if (Face == 2)
return plane(vector(__ZEROMM, __ZEROMM, ZMax), vector(0, -1, 0), vector(1, 0, 0));
function createMainBody(context is Context, id is Id, index is number, XMax, YMax, ZMax is ValueWithUnits)
var sketchID = getID(id, __SKETCH, index);
var extrudeID = getID(id, __EXTRUDE, index);
var sketchplane = createsketchPlane(context, XMax, YMax, ZMax, 1);
var sketch = newSketchOnPlane(context, sketchID, {
"sketchPlane" : sketchplane
skRectangle(sketch, getID(__RECTANGLE, index), {
"firstCorner" : vector(0, 0) * millimeter,
"secondCorner" : vector(XMax, YMax)
skSolve(sketch);
// Without extrude sketches are made
opExtrude(context, extrudeID, {
"entities" : qSketchRegion(sketchID),
"direction" : sketchplane.normal * -1,
"endBound" : BoundingType.BLIND,
"endDepth" : ZMax
return qCreatedBy(extrudeID, EntityType.BODY);
function createCutOut(context is Context, id is Id, index is number, XMax, YMax, ZMax is ValueWithUnits, Face is number, XPos, YPos, Width, Height, Depth is ValueWithUnits)
var sketchplane = createsketchPlane(context, XMax, YMax, ZMax, Face);
"firstCorner" : vector(-XPos, -YPos),
"secondCorner" : vector(Width, Height)
skSolve(sketch);
"endDepth" : Depth
function getID(id is Id, name is string, index is number)
return id + name + index;
function getID(name is string, index is number)
return name ~ index;
Hi Frank,
Looks like your issue is "revisiting" the sub-id named id + "sketch". That sub-id needs to refer to a contiguous region of history. I suggest reading the documentation for the Id type, which describes this issue.
A good fix is probable changing your getId() function to return id + index + name, or perhaps id + (name ~ index).
The error should be described in the notices flyout when you visit the Part Studio. When debugging it's also helpful to click "Monitor Part Studio 1" in the top right of your Feature Studio so you get feedback from runtime errors like this shown directly in your code whenever you commit a change (in this case, a warning underline on skSolve with the error described)
Hope that helps!
PS – In the future, linking to public document is more helpful than posting code, since this lets others immediately see the error state (and, as your FeatureScript gets more complex, shows us how you're using the feature in a Part Studio and handles imports correctly). If it's a work in progress, linking to a version is even better!
5
Hi Frank,
Hope that helps!
5 -
Thanks Kevin!
I changed the getID() function, that solves it (your link was very helpful).
I keep your PS in mind in case I have other questions.
