External Parts Assembly Names and Instance References
emil_4
Member Posts: 5 ✭
Please allow renaming instances (external references of imported parts?) to use descriptive titles that make common sense
Onshape is built for a top-down, multibody workflow, so each body you create in (or import into) a Part Studio is a part and has its own unique name which you can change as you see fit.
Does that help solve your problem?
UX/PD/Community Support
