Improvements to the Beam profile generator
emagdalenaC2i
Member, Developers, Channel partner Posts: 867 ✭✭✭✭✭
As I mentioned a few days ago, I made some improvements to Neil Cooke's code to generate beam profiles.
With this improvements you can create as many profiles as you want in a Part Studio and copy & paste all the output code of the FeatureScript notice panel to the "entries" section in the Beam Profiles code.
C2C - Profile generator
I will create a video to explain in detail how it works
The example Part Studio "Perfiles EcoSafe" is part of our complete profiles library. There you can see 4 sketches and a Profile generator feature for each sketch. This is the output code:
Note: You don't need the extrude features to create the profiles. It just let you to create a derived part of that beam, place it and change its lenght with Move face.
Here are the list of changes:
- There is a new text field to insert the name of the profile
- The new features created will be named by default "Profile " + Profile name
- Units are set to millimeters by default
- The output in the FeatureScript notice panel are cleaner, show all the information needed to create a new profile in the right order.
- I have changed the name of the command to avoid any troubles with the original code
Un saludo,
Partner de PTC - Onshape Averigua a quién conocemos en común
7
