Can I determine the internal volume of an assembly?
rick_piccerillo976
Posts: 1 ✭
I wanted to know if there is a way to see the volume of the empty space within an assembly? Ex. I have a t-joint with fittings mated to part. I was curious about the volume of the empty space within the assembly.
I don't think there is a way to do it within an assembly easily (I could be wrong) but within a part or part studio, you can create a solid with boolean operators that is essentially the empty space within a component, and then measure the volume of that.0
It's a bit fiddly, but what @ben_misegades435 said, plus that you can create part studios in context from assembly, meaning you can use assembly parts for your booleans."A common mistake that people make when trying to design something completely foolproof is to underestimate the ingenuity of complete fools." - Douglas Adams, Mostly Harmless0
A long GIF, but here you go.
Happy Friday!
Jason
https://cad.onshape.com/documents/21c5898b878f3341ccff290f/w/933f2e4f2654dbbf58f052b2/e/257c7611675665e0c30da646
Support & QA0
