roll tape
eric_mendez336
Member Posts: 2 ✭
Dear mister OnShape, i want to make a roll tape with the helix tool, but it can´t select mi circle face, just works on extrude, can you help me to make my roll tape
i would apreciate that a lot
Thanks, best regards to you mister OnShape
To make a helix, you need a cylinder face to select.
The simplist way is to extrude your circle as a "surface" to the height of your helix.
When you say "roll tape" I imagine a spiral instead of a helix. OnShape doesn't have a spiral tool yet, but someone may have a featurescript that makes spirals.0 -
You could create a conical surface, create a helix, then afterwards create a sketch and "use"
the helix.Senior Director, Technical Services, EMEA3 -
Sneaky way to create a spiral, like it!NeilCooke said:You could create a conical surface, create a helix, then afterwards create a sketch and "use"
the helix.
HWM-Water Ltd0 -
@john_mcclary
I wanted to try it so forgive me butting in.
Here be:-
https://cad.onshape.com/documents/d51ecfd36f3d4a30b03c1f21/w/b167d8936840aa422688480a/e/3d71b72c2d6614dce2e37afc
(1) Extrude cone
(2) Helix on cone
(3) Use/Project helix onto new shetch.
Owen S.
HWM-Water Ltd0 -
@eric_mendez336 The example document above now has some "tape" with the addition of the sweep of a line to make a surface and then a thicken of the surface. (This seemed more robust than a solid sweep of a rectangle.)
Owen S.
HWM-Water Ltd1 -
Ah a cone
He said conical surface.. so i thought he was showcasing the new conic sketch command. lol
Thanks @owen_sparks for clearing that up
Its nice to know helix can be wrapped around more than just cylinders. Good job OS0
