skText too big, how can I define its origin and sizes on sketch?
Think the title says it all, I want to place the text in a certain position (above my aerofoils) also, changing skText to construction doesn't seem to do anything?
Kind regards,
Darren
Kind regards,
Darren
The box around the sketch text can be dimensioned similarly to other sketch entity. Additionally, you can position sketch text by setting a coincident constraint between any of the 'snap points' on the box and some other sketch vertex. Here is an example of sketch text which is dimensioned and anchored to the origin:
https://cad.onshape.com/documents/0d853e17ab2575bee74ac3a6/w/d0bc950f7cd53294625170ba/e/bc1d1373efc9578dc2b2f2f2
Currently sketch text cannot be made into a construction entity. Out of curiosity, what is your use case for construction text? Feel free to submit an improvement request on the right if you would like to see this functionality in Onshape
You can do it with skContraint, but setting the initial guess correctly becomes tricky. Instead, what people usually do is to just create the sketch with huge text, then use opTransform to move and scale the resulting entities to the desired position and size.
Here's a document which demonstrates the idea:
https://cad.onshape.com/documents/cdbad61ec176b39049f8d4c1/w/0cb06ca7cb2788345cc7a448/e/c1778a16ae172747eaf7b147
In this doc's feature, the transform (both position and scale) is determined by a selected sketch line. The doc for opTransform might illuminate other methods of creating the transform you need.
Many Thanks,
Darren
"firstCorner" : vector( xPosition, yPosition),
"secondCorner" : vector(xPosition+1*inch, yPosition + textHeight)
Further explanation posted in the thread https://forum.onshape.com/discussion/8269/how-do-i-scale-sktext-in-situ-from-featurescript
