Best practices for workflow?
preston_bannisterpreston_bannister Member Posts: 6
In my case, I am exporting parts from Onshape, importing into Cura - with adjustments, saving the gcode to removable storage - with renaming, and printing on my 3D printer (a Chinese clone of the Prusa i3).
As a software guy, I am accustomed to saving anything repetitive as Make/Ant/Maven recipes (or the like). Fiddling around in a GUI is fine the first time or few, but after I want to write recipes.
I have no notion what is usual practice in the CAD community. What is usual practice? What does Onshape support?
I can hack Cura (if needed), as it is open source. Not looking to re-invent where there is existing practice (if there is existing practice).
  • mbattistellombattistello Member, Developers Posts: 51 EDU
    Ive not seen anyone automating this workflow. Im familiar with make/ant tools and I think I understand what your trying to get at.
    You could automate the exporting processes from Onshape with the APIs. You could build a custom task that can interact with the Onshape APIs. I have an app that does the download of an Onshape model to a step file locally and then imports it into another CAD platform and manipulates it.
    The one challenge is you can only export a couple formats ( think just Parasolid ) in a single step. The other formats require you to setup a webhook listener that Onshape notifies when the its completed the translation. This might cause a small issue if you want this process to be solely run on your desktop as the webhook wants a url to call. I think you can take another approach where you request the export/translation and then poll for its status and when its complete download it.
