What does NO_ERROR mean?
kendall_frey
Member Posts: 2 ✭
I'm trying to use skEllipticalArc in a feature, but every time I give it a center that is not the origin (0,0) it produces NO_ERROR and doesn't create the arc.
Here is the simplest code that reproduces it:
<div>FeatureScript 581;</div><div>import(path : "onshape/std/geometry.fs", version : "581.0");</div><div><br></div><div>annotation { "Feature Type Name" : "Test" }</div><div>export const myFeature = defineFeature(function(context is Context, id is Id, definition is map)</div><div> precondition</div><div> {</div><div> // Define the parameters of the feature type</div><div> }</div><div> {</div><div> var sketch1 = newSketch(context, id + "sketch1", {</div><div> "sketchPlane" : qCreatedBy(makeId("Top"), EntityType.FACE)</div><div> });</div><div> skEllipticalArc(sketch1, "ellipticalArc1", {</div><div> "center" : vector(2, 0) * inch,</div><div> "majorAxis" : vector(1, 0) * inch,</div><div> "minorRadius" : 1 * inch,</div><div> "majorRadius" : 2 * inch,</div><div> "startParameter" : 0,</div><div> "endParameter" : 0.25</div><div> });</div><div> skSolve(sketch1);</div><div> </div><div> });</div><div></div>Is this a bug? How can I create an arc where the center is somewhere other than the origin?
It turns out that this is a bug. When sketching interactively, none of the arguments to skEllipticalArc are used, so I never noticed that one of them doesn't work properly. As a temporary workaround, it's possible to use skSetInitialGuess. skSetInitialGuess takes in a sketch and a map of sketch entity ids to arrays. This is used to place those entities in the sketch. Using it would look something like this.
var sketch = newSketch(context, id + "sketch1", { "sketchPlane" : qCreatedBy(makeId("Top"), EntityType.FACE) }); const initialGuess = { "ellipticalArc" : [2, 0, sqrt(2) / 2, sqrt(2) / 2, 1, 0.5, 0, 3] }; skEllipticalArc(sketch, "ellipticalArc", { }); skSetInitialGuess(sketch, initialGuess); skSolve(sketch);The initial guess data for an elliptical arc is in this format: [center x, center y, major axis x, major axis y, major radius, minor radius, start parameter, end parameter] All distances are in meters, the parameter's domain is [0, 2 pi], and the major axis will not be normalized for you unlike with the skEllipticalArc function.0 -
The fix for this went out in our last update. Like many fixes, it only affects new and upgraded Part Studios.0
