Drawing Attributes
zac_jeckell
zac_jeckell Member Posts: 4 ✭
Is there any way to change the attributes in a drawing? I need to be able to control line width and color to produce part negatives for photochemical etching.
  • PeteYodis
    PeteYodis Moderator, Onshape Employees Posts: 594 image
    @zac_jeckell  It's certainly possible to download the DWT file that is being used for your Onshape drawing template and edit the properties of the layers to get the appearance you would like for your drawings.  You would need a local DWG editor to do this.  After saving that result, you can then upload the DWT file and use it as your own drawing template.  We do intend to allow our customers to get the appearances of their drawings as they would like fully within Onshape, but the solution I mentioned here would work for you today.
