Bug Report: Circular pattern dropouts depending on what object used for center of Axis
Member Posts: 46
In this forum post, we discussed an error in the circular pattern tool:
https://forum.onshape.com/discussion/comment/29038#Comment_29038
The last object created with circular pattern disappears if I use the edge of an extruded object created within that part studio (called 'center') as the center of axis but works properly if I use the inner surface of a derived part.
I can't see anything incorrect that might contribute to this problem
