Revolve around Document or Object Access ?
ethan_rosch
Member Posts: 5 ✭
I'm trying to rotate a portion of a sketch.
When using the rotate tool, it asks me what axis i want to rotate around.
I really want to rotate around the objects own center point Z axis and/or the origin Z axis (as the object is aligned to the origin).
If I'm understanding this correctly, I need a sketch line or part line to revolve around.
Steps would be:
Thanks
Ethan
Steps would be:
- Create a plan that bisects the desired rotation object
- draw a vertical line which I want to rotate around
- go back to the object and rotate around that new line
Thanks
Ethan
Hi @ethan_rosch you should be able to sketch the line in your profile sketch. If not the method you mention will work.Senior Director, Technical Services, EMEA0
