Crane dynamics
miguel_rodriguez_lorenzo
Member Posts: 3 ✭
I tried to simulate the dynamics of a crane.
See my assembly in the following link:
https://cad.onshape.com/documents/e1a067799cdc42185e3a6af3/w/88ada7c4418438341dc4e96d/e/d05c897c7871a0278a6670dd
The crane has following parts: 1) Base ; 2) Vertical tower; 3) Boom; 4) Hyd. cylinder; 5) Hyd. piston.
The crane dynamic should be: a) Vertical tower can rotate around the axis Z; b) the boom can rotate around axis Y; c) Hyd. piston push the boom until the boom reach the vertical position and go back.
The problem is: How to simulate the whole crane dynamics, in particular the case c) above ?
Thanks
Thanks
mahir
Member, Developers Posts: 1,324 ✭✭✭✭✭
Will this work? I didn't change much except for moving all the mate connectors to be centered. It makes mating a lot simpler since all pins will automatically be centered in their slot.
https://cad.onshape.com/documents/da083cf8b3b4c2a3b89039f0/w/5b5e7f3f174793cf174c5d29/e/ba9de1617fd85d1242f3d0bf
1
