Segmenting an existing line
alekesey_k
alekesey_k Member Posts: 5 ✭
edited May 2017 in Community Support
Can I segment an existing line?
Tried adding points but those don't segment the line i.e. I'm not able to select separate segments after placing the points on the line.
I added a construction line and now want to add several equally spaced points on the line for the hole feature to have equally spaced holes.
If I draw a line in several segments to begin with then I can select all the segments and add an equals relation to make the segmenting points equally spaced.
