How do I align the holes in a circular pattern in two flanges?
In the link below, I created two flanges ( A and
with holes.
I tried to align the holes (flange A with flange NB) with a revolute mate but it seems to me that is not the best way.
Any help, please?
https://cad.onshape.com/documents/8f30778a13007baac5796207/w/3654b465acf71498c52dd51a/e/b2c1807ff7d0b540f64de878
Any help, please?
If the default alignment doesn't work for you, you can re-define the orientation relative to any edge or sketch entity.
In this example, i only made two simple changes.
In Flange A i attached the center of the sketch pattern to the origin (there was no constraint)
In both flanges i adjusted the location of the starting circle to lie on one of the primary axes.
No changes to the Mate Connectors or Mates was required.
https://cad.onshape.com/documents/48eab22731b170edf6b6b687/w/58e46db4246124e084384b61/e/89f69ceba69eb8ce94ba2574
https://www.youtube.com/watch?v=_79kNCpke7o
