Why can't I copy and paste part of a sketch to a new surface parallel to the original?
I essentially of 2 parallel disks an inch apart from each other. I have a geometric pattern cut in to one of the disks and I'd like to mirror that pattern to the other disk so I can make the same holes using extrude. I'm unable to simply adjust the extrude depth so that I can cut through the bottom disk from the top.
Have you tried using the USE (project/convert) command?
Make sure your previous sketch is visible so you can pick the features from that sketch.
The shortcut key is u to enable
