Can't assign a material
virak_simvirak_sim Member Posts: 4 EDU
Hi in part studio 1 i can't assign a material. It's strange because I can't even select a part it shows "Parts (0)". Thank you
  • noanoa Onshape Employees, Developers Posts: 141 image
    It could be that what you are seeing are actually surfaces, not parts. Only parts can be assigned a material.
    If you make your document public and post a link here, we can take a look to be sure this is the case.
    Noa Flaherty / Customer Success / Onshape Inc.
  • virak_simvirak_sim Member Posts: 4 EDU
    So here's an update, after a while (maybe 30 min) it came back to normal
