OAuth: 401 error when attempting to get a token
james_mann066james_mann066 Member Posts: 2
I'm in the process of handling the OAuth page lifecycle for an app in Onshape. I am using the guide called "Using OAuth 2.0 with Onshape" on the Developer Portal. I'm testing the page lifecycle in a crude manner via the OnshapeWindowsSample project from GitHub.
I've registered the application and setup the response page to be at localhost. Thats all good.
I direct the user to a URL from which they log in and I get back a "code" in the querystring. Thats also good.
But then I attempt to create a http form request containing some data plus the authorisation code from above. This is where I am getting a 401 error: "The remote server returned an error: (401) Unauthorized."
I'm getting this error using the exact code provided by Onshape on GitHub so I'm a little confused why I'm getting this error.
Any ideas?
  • awkawk Member, Onshape Employees, Developers Posts: 78 image
    The most likely cause is that the form you're posting is incomplete/incorrect. I'm not aware of any errors in the Windows sample, but it's certainly possible something has 'wobbled' 8-(
    The body of the form needs to contain the client ID, client secret, authorization_code (the code you get in the query string you mentioned) - additionally if you specified a redirect URL it needs to be included in the POST body too.
    Each of the parameters in the POST body need to be URL encoded - this especially important for the Client ID and secret since either or both may contain multiple trailing '=' characters which must be converted to '%3D' and must be in the POST body. You should only encode the individual values in the form - encoding the entire form will cause all the '=' characters to be replaced, including those required to separate form values & form keys.
    I've seen some higher level HTML/HTTP frameworks do the URL encoding of form values for you automagically. Which can mean that the form contents get double-encoded, which will also cause failures. Being familiar with the details of any helper framework you're using is a good thing :-)
    Lastly - if you want to email 'api-support@onshape.com' we can provide you with some more personalized support.
    Director of API, Appstore, and App Partner Technical Support
