A question on preconditions.
darren_13
Member, Developers Posts: 120 PRO
Can I somehow separate the preconditions out of the main function?
there are two reasons I wish to do this:
If 2 is not possible I can work around but number 1 would be good.
Many thanks,
Darren
- it's getting too long and messy.
- I want to take a precondition of queries and split it and return it in two separate definition maps i.e. definition.plane and definition.lines, I could split it into two queries from the start but I wanted it in 1 query to reduce clicks.
Many thanks,
Darren
1. You can write a predicate and use it as a line in precondition. See
booleanStepScopePredicate() implemented in boolean.fs and used in extrude and other features precondition.
2. Precondition can't change definition, so you'll have to split your input with qGeometry() filter inside the feature
