Issue with finishing a sketched Spline
mitchel_palmermitchel_palmer Member Posts: 20 ✭✭
Hi there
I have noticed that if you right click and press "escape spline" the spline disappears. Unlike sketch "line" where it completes the command and leaves the line. it would be great if this could be fixed or your could use enter to complete the command.
Currently you have to double click the left mouse button to complete the spline. Which is ok, but you have to make sure your pointer is where you want the last point to be, else it makes another segment. Sometimes, even double clicking on the final point, results in minute extra segments sometimes.
    edited July 2017
    Hi Mitchel,
    You can press the 'esc' key to finish the spline without adding another point.
    Please file a bug with us about the "right-click>escape spline"  by clicking the "?" menu in the top right corner of your part studio, and then clicking "feedback".
  • mitchel_palmermitchel_palmer Member Posts: 20 ✭✭
    done :)
