Unable to create drawing from imported part
ihor_gernaga
Member Posts: 24 PRO
I have a solidworks part which is not solid. It is just a shell. I presume it is because of not being a solid part? My next question would then be, can I convert the imported part to a solid?
Onshape does not currently support creating drawings from surfaces. I will add you to that improvement.
In the meantime you have a couple of options to turn the surface)s) into a solid and then create the drawing:
Use the thicken feature to add thickness to the surface
https://cad.onshape.com/help/#thicken.htm?Highlight=thicken
Use the enclose feature to make a solid from the surface by selecting additional surfaces, solid faces and planes
https://cad.onshape.com/help/#enclose.htm?Highlight=enclose
Andy Morris / Head of Product Design / Onshape, Inc.0
