Issue with Creating Rib on outside of a part
in General
I need to make a very complex set of ribs on the outside of the part. I created a midplane on the part and then did a intersection of the plane and external surfaces to get my geometry. OnShape doesn't allow me to create a rib projecting outward normal from the part. I then offset my geometry and tried to create the rib but it won't create the rib from the geometry for the entire curve. The normals appear to be flipped on two of the segments. Any thoughts?
