Trouble with extrude
3966_cad
Member Posts: 10 EDU
I am using extrude instead of opExtrude, but it keeps saying that the EXTRUDE_FAILED.
Here is the link.
extrude(context, id + "extrude2", {
"entities" : qSketchRegion(id + "sketch2"),
"oppositeDirection" : true,
"endBound" : BoundingType.UP_TO_BODY,
"operationType" : NewBodyOperationType.REMOVE,
"endBoundEntityBody" : qCreatedBy(id + "sketch2", EntityType.BODY)
});If anyone can help, it would be much appreciated. Here is the link.
Two things I can see:
On extrude1, I believe in"endDepth" : definition.length * inch, you should remove* inch, since definition.length already has length units.
On extrude2, you seem to be extruding a sketch up to bodies from that same sketch, so the extrude depth is 0 everywhere. I'm not sure what your intention is but I assume that's not it?
