Is there a way to draw a zig zag or wavy line in Onshape?
lundmikkel
Member Posts: 2 ✭✭
I've searched the web multiple times, but without any luck. It seems other
programs that work on vector/math based models (like Illustrator) has
tool support for that, as demonstrated in this video: https://youtu.be/z0PD9ifGtHc, but I can't find any equivalent in Onshape.
Hi @lundmikkel like you say it is easy in vector drawing programs. To do that in a parametric CAD system you will have to sketch it. You can use equal constraints and pattern to help you though.Senior Director, Technical Services, EMEA0
Following what @NeilCooke said. Take a look at this document. If you make a copy and edit the sketch you can modify the "2X" to instance the pattern to as long as you want.
https://cad.onshape.com/documents/90d4335b77f273471422b74b/w/62624cd1d8dd28156c77b847/e/2fe2802ae72e8e1680fd3639
