Sketch dim entry in/mm units case
robert_bilbreyrobert_bilbrey Member Posts: 2
I wish when entering a different units dimension in sketches that OnShape would be smart enough to realize that 1.50 MM has the same meaning as 1.50 mm.  I usually keep uppercase locked (by habit) when doing CAD work.
    Yes I agree and also 1" is the same as 1in.
  • john_mcclaryjohn_mcclary Member, Developers Posts: 4,048 PRO
    Agreed. This should not be case sensitive.
    This is a good candidate for an improvement request if one of you would like to make one.  (See 'Improvement Requests' on the right side of this page -->)
