Move holes on a cylinder?
mrmagnemrmagne Member Posts: 6
Hi,
I have made this cylinder with holes around it and i would like to move the holes in a V shape around the cylinder (mirrored on each side). Now, i have tried to use the dimension tool to try and set a length from the cylinder side wall to the center of each hole, but that is not working.
Any tips for me here? Sure would appreciate it :)
    @mrmagne - Onshape is a very powerful professional grade 3D CAD platform. Please check out the Onshape learning center for awesome tutorials.
    www.learn.onshape.com.
    To get you going, here is a quick public document showing what i think you're asking for :)
    https://cad.onshape.com/documents/1f863cbbcea49bed45409618/w/3abb3b92d9cf642a9de9fc28/e/68fe3dd5192ac5bbf4676567
    Philip Thomas - Onshape
  • mrmagnemrmagne Member Posts: 6
    Hi @philip_thomas and thanks for your effort :)
    Your example was not what I was after, sorry if my explanation was poor.
    Try visualise a rectangular square with one large V on the whole surface, i then want holes along the whole V, then transform the rectangle to a cylinder. So when the top and bottom of the V meets on the cylinder, i would get two holes on each edge of the cylinder where the top of the V pattern is and one hole in center just below the top holes.
    @mrmange - sorry, no idea what you're describing. How about drawing the pattern unrolled onto a piece of paper. Take a picture with your phone and post it here. It will take 5 minutes to model whatever pattern you draw. :)
    @philip_thomas Hope this drawing helps.
    First image would be if i set the cylinder standing on a table looking right at it.
    Second image would be of the cylinders whole face, looking at it on a rectangular perspective.
    Thanks, with some tweaks i think i can use this method. The method is currently to complex for my skill level, but i will study and learn it :)
    If there is an easier way to achieve this, let me know :)
Howdy, Stranger!
