Failure to Regenerate?
How do I fix an extrusion that failed?> What does that even mean? I haven't been able to find anything in the Help site.
christopher_day719,
An extrusion failed implies that the result of the extrusion operation did not result in a valid geometry. One tip is to start the extrude with small values and then work your way up until you get the error.
You can also share a link to your document on the forum. This will allow us to help you figure out what exactly went wrong.
We are guessing unless you post a public linkPhilip Thomas - Onshape0
