Failure to Regenerate?
How do I fix an extrusion that failed?> What does that even mean? I haven't been able to find anything in the Help site.
    Paul_J_PremakumarPaul_J_Premakumar Member, Onshape Employees Posts: 199
    christopher_day719,
     An extrusion failed implies that the result of the extrusion operation did not result in a valid geometry. One tip is to start the extrude with small values and then work your way up until you get the error.
     You can also share a link to your document on the forum. This will allow us to help you figure out what exactly went wrong.
    We are guessing unless you post a public link
    Philip Thomas - Onshape
