Get vector for edge direction
DSPuzzles
DSPuzzles Member Posts: 17 EDU
I am writing a feature that requires me to select a vertex and returns the vectors corresponding to the direction of the edges that meet at that vertex. Is this possible?
Thank you.
  • lemon1324
    lemon1324 Member, Developers Posts: 230 EDU
    edited August 2017
    Yeah, should be pretty straightforward.  Head to the documentation and check out the qVertexAdjacent and evEdgeTangentLine functions.
    Arul Suresh
  • kevin_o_toole_1
    edited August 2017
    Definitely! I made a public doc as an example:
    https://cad.onshape.com/documents/71cf88a8c2e0951f0f60de72/w/8c5180c50706c37a3c028753/e/eb84571c61056de69feff247
    The underlying functions here are qVertexAdjacent and evEdgeTangentLine.
    Let us know if you have more questions!
  • DSPuzzles
    Thank you very much!
    A follow-up question for the same feature, how do I specify in a query for vertices that I want to allow the selection of midpoints of edges? Whenever I use "Filter: EntityType.VERTEX" I can never select these, while in OnShape features like the transform tool in translation mode I am able to select these points. I've looked through the source code but cannot seem to find a reason for these
  • Jake_Rosenfeld
    Hello!
    For various development reasons edge points (our internal name for edge midpoints) are only created if edges are selectable into the box in question.  The filter "Filter: EntityType.VERTEX || EntityType.EDGE" will allow you to select those edge points that you want to get at.  It will also allow you to select edges, which may not be desirable for your feature.  The following code may be helpful:
    if (size(evaluateQuery(context, qEntityFilter(definition.point, EntityType.EDGE))) > 0)
        throw "Feature does not support edge selections, select vertex or midpoint";
    This bug is on our radar, but you can help by clicking "report a bug" from the "?" menu in your Part Studio.
    Hope this helps!
