Queried entity type evaluation
konstantin_shiriazdanov
Now if your query supports several entity types (geometry types, body types) and you need to process them differently you have to create a number of constructions like
if (try silent evSomethig is Somenting) {}
else if (try silent evSomethingElse is SomethingElse) {}
and it seems to be not very elegant for the task of finding out what entity/geometry/body contains the query.
Am I missing something or there is a reason to ask for implementation of function like evQueryContetntType(query) which should return a map like {"entityType":entityType, "bodyType": bodyType, ''geometryType":geometryType} for a query refferensing single entity.
  • kevin_o_toole_1
    Generally speaking we prefer to use queries rather than evaluations to solve filtering problems. They are more efficient, they're lazily run, they don't give the user data which can go out of date, and (hopefully) they involve writing less FeatureScript.
    For your case, can e.g. qGeometry() be used to do the job? If not, why not? We can certainly look into adding more queries like a qGeometry with multiple types, or a qHasAxis or qHasDirection to correspond with evAxis and evDirection.
    For something like evSurfaceDefinition, I'd say your construction actually is good, canonical FeatureScript. One alternative is to wrap each in e.g. if(evaluateQuery(qGeometry(...)) != [] ). I think you'll find that the performance is about the same (since the ev functions themselves will fail early).
  • konstantin_shiriazdanov
    edited August 2017
    For example in my Measure distance extended FS for angle evaluation a have to extract direction vector from entities that have axis and normal vector for planes, and i have to wrap it into if-else tests. For two entities I had to write four tests - this doesn't look like reducing amount of code. And i can remember several more cases when i would like explicitly know queried entity type instead of bulky tests, at least so is my thoughts.
  • ilya_baran
    ilya_baran Onshape Employees, Developers, HDM Posts: 1,272 image
    The request makes sense to me.  The modifications I would make to the proposal are: not restrict it to one entity, but return an array of maps, and also include the transient query in each map.  This may also be a good way of returning other cheap-to-get per-entity info, such as whether it is modifiable, construction geometry, or belongs to a sketch.
    @ilya_baran, thank you for your attention, should I make this an improvement request?
  • ilya_baran
    Yes, please.  That'll ensure that you get a notification email when one of us implements it.
  • Jake_Rosenfeld
    edited August 2017
    @konstantin_shiriazdanov
    Go check out 'extractDirection(...)' in 'topoloyUtils.fs', as well as 'QueryFilterCompund.ALLOWS_DIRECTION' in 'query.fs'.  It doesn't solve the wider problem you are asking about, but it is a built-in way of doing what you want in Measure Distance.
    thanks @Jake_Rosenfeld, it would somehow simplify the code
  • Kyler_Walker
    Kyler_Walker Member Posts: 211 ✭✭✭✭
    I think I have a similar situation.  I'm trying to get a direction vector from a face or edge.  The direction will be determined differently depending on the entity chosen.  Is @Jake_Rosenfeld's suggestion my best option? Should I use qGeometry() and check if the result is an empty array?
  • MichaelPascoe
    MichaelPascoe Member Posts: 2,935 PRO
    edited September 2021
    Has this been implemented? If not, where is the correct place to vote?
    Found it:
    https://forum.onshape.com/discussion/7074/feature-script-queried-entity-type-evaluation
    RENDERCAD
  • Alex_Kempen
    Alex_Kempen Member Posts: 258 EDU
    @Kyler_Walker If you're seeking a direction, you can use QueryFilterCompound.ALLOWS_DIRECTION to enable direction selection (or a subset of direction entities, like GeometryType.PLANE || EntityType.EDGE), and extractDirection to cleanly convert that direction into a vector. extractDirection will automatically choose the direction correctly based on the type of selection; the face normal if it's a face, the edge direction if it's an edge, the cylinder axis if it's an axis, etc.
  • Kyler_Walker
    Thanks. That does exactly what I want.
