iphone app recent commands
AlexArevalo416AlexArevalo416 Member Posts: 7 ✭✭
Hi Onshape,
really impressed with the latest update to the iphone app.  it would be nice if there was running history of recently used (or most used) commands on the top bar, where the active command is or in the "two finger tap" menu
  • rbaekrbaek Moderator, Onshape Employees, Developers Posts: 77 image
    Hi @AlphaBlu, how would you expect to see your recently used commands? Would you expect them to appear in the area you pointed out in the screenshot, or would you expect them to appear in a dropdown?
    If you have any suggestions, feel free to shoot a submission via the Feedback modal under the Help (?) menu.
  • AlexArevalo416AlexArevalo416 Member Posts: 7 ✭✭
    thanks @rbaekI would say in the area i pointed out in the screenshot (so there is less tapping) and to avoid going to drop downs as often as possible.
    in the "two finger tap"menu would also be a nice compliment to it as well.
