pro-e import
I have huge .asm pro-e file imported mostly shrink wrap models imported as a zip file . I can clean up the assembly's so it works quite well.
But the corresponding part studio wont open because the browser crashes, some times it says out of memory. I need the part studio file to open so I can change and delete parts. It gives me no clue why it wont open maybe my hardware can be the problem
auto_load_rig_comp parts.zip
auto_load_rig_comp parts part studio wont open
dockument hp
dockument hp
Did you try unzipping the file first and then importing the files?1
You can check your browser memory consumption or try Firefox (I believe it is better with memory).
Alternatively you could rename the zip file to one of the smaller sub assemblies and reimport, then it would only create a part Studio with a smaller number of parts. Or like Chris says, import some of the larger parts individually.
I am guessing the shrink wrapped parts are mostly surfaces? Nasty.Senior Director, Technical Services, EMEA1 -
Thank you I try your suggestions or clean the pro-e file before zip an reload all. Its surfaces most , I need the part studio for some minor changes.
I wish it was possible to lock two or more parts together while dragging (mechanism) it is a drill rig with 5-8 parts to position . I have big problems dragging the parts to exact position.0
