How do I angle a tube?
gyrex
gyrex Member Posts: 38 ✭✭
Hi guys,
I'm having a bit of a brain fart and can't figure out how to do something relatively simple I guess.
This is my drawing: https://cad.onshape.com/documents/103df7df35e7f8b79d212ded/w/6b205c965461e2886eab2c08/e/3b22df7d8a7aec1baa7e0220
I have a tube running vertically and I'd like to angle the tube at 20º from the vertical. I've tried doing a revolve but it doesn't work out exactly as I thought it would. The edges don't match up and it protrudes into the existing vertical tube cavity.
Can someone help me please?
Many thanks!
John
  • gyrex
    I solved my own question. I did a search and found the shell function. I've been extruding tubes in the past but I've learnt about this wonderful shell feature!
    My example of how to do this is here:
    https://cad.onshape.com/documents/ba898f98d27e921d446e8cd5/w/8a83444be4c6cbc1fa9a67c7/e/b7e47a20414160859945ca7d
    I used a combination of loft and shell. First I extruded the vertical cylinder (without drawing the inner part to make it a tube), then I created a sketch to create the desired angle on the front plane. Then I created a new plane where I wanted the tube to finish up, drew an equal circle on the new plane at the desired location, lofted the 2 circles together then used the shell function.
    I love onshape! Learning something new every day :)
