Unfold cylindrical Surface
Hi,
I'm new to Onshape and try to work me in.
Now i have Designed a part for a new projekt.
The Part: https://cad.onshape.com/documents/14a9efceed7c7be4ca3ebfcf/w/dfab4f756c09c59f6a2a6850/e/01d19c9c0085f6738a64102f
(hope this Link works)
Is it possible to get an unfolded view of the outer cylindrical Surface ? it does not matter where the surface is "cut" to unfold.
The idea is to print out this unfolded view in 1:1 scale and glue it onto the raw material and then use this mask to cut it out.
Actually the Part is for 3d printing, but for no reason i want to know how to do the unfolding
Greetings
Tredory
Greetings
Tredory
Owen S.
HWM-Water Ltd
https://cad.onshape.com/documents/3c0722b6da310e3810a57cd2/w/8d928bb8f9eaa2e0e412729e/e/4ddc302232ca9af35986a1b6
Thank you. Thats great !
I am having trouble with your General Cone Unfold - it's worked well for me up until V35.
Here's the feature using V36:
And here's the feature using V34:
I made the same selections for both versions.
The surface that is being unwrapped is a revolved surface, with a trimmed-out portion so that it's not continuous.
Is there something I should do differently so the new Version will work? (BTW, the sketch unwrapper FS didn't seem to work on this geometry either).
Thanks!
Romeo
It took me a few minutes to remove the private bits from the file.
Here's a public document: https://cad.onshape.com/documents/8688b9c2f0fdaadd6e3f3330/w/4e2efd77ce16c1b7e38b2908/e/d1bc41f242708a9140310994
When I update the General Cone Unfold FS, the sketch created is incorrect.
Thanks!
Thanks,
Romeo
I am having trouble understanding how to create an unfold for a sheet metal cone. Using the General cone unfold does not seam to produce the correct result. Is there perhaps further explanation of how to use it correctly and the limitations of the script?
I have been testing it on the following example part:
https://cad.onshape.com/documents/a9ae792128b0edfad550670c/w/e047a7bf0dc050ab91ab5bc0/e/41960ca9a39337306454c482
Thanks,
Renier
Thanks,
Renier
Tried to follow your advice with the two feature scripts. Sketch Wrapper and Fold didn't quite work as I expected.
Can anybody help me to unfold the intersection line to the top datum plane or mate connector?
https://cad.onshape.com/documents/b9d23f7702cc34d9e52c85b6/w/085b6d0bd117d8a34b9e4bd1/e/176fd507387fb4291eceef4f?renderMode=0&uiState=63bc84f105567d5fe6f4f0d2
But can do this
https://cad.onshape.com/documents/bd3ee59ecd36879dc4d61eb5/w/31c75f172767a9934d13d609/e/45ae11778ed30e6311003c6b
Did a thicken of .0001 in both directions of the curved surface
Then a Boolean subtract to cut the cylinder
Then an unwrap
That's kind of what I was looking for. Is there a way to unwrap it and keep the coordinates under control. I would like to attach it / unfold it so the mate connector will be fixing point for the unwrapped curve.
When you use the unwrap, it does not create a part or a surface — at least not one that is LISTED
So from the wire that it creates within the sketch or modeling window, I used FILL to create a surface
I next modified the location of your Mate Connector to where it was at the center of the line
Then I put a Mate Connector at the center of this new surface created using fill
Then used Transform (by mate connectors) to move this surface created with fill over on top of the original mate connector
In the link to the document in my post above, look at the part studio called Aligned
edited the document
Something looked funny so I took a look at things from a right view and saw what I did.
I had to rotate the second mate connector around the Z-axis 180°
Thank you very much for your help steve!
