Changes to sketch tools after Sept. 8 update
james_kennedy096
Member Posts: 3 ✭
in General
After the Sept. 8 update, many basic sketch tools (circle, rectangle, curve, etc.) are not available. When I click customise toolbar, it says that all available tools are on the toolbar. Is this change intentional.
jordan_simonds
Onshape Employees Posts: 3
Hey James! This is not intentional, your toolbars should have the same tools as they did before.
Can I ask which browser you are using? We are tracking down a similar issue with older versions of Safari.
Also, if you haven't already, please submit a support ticket so we can let you know if/when the issue is fixed. thanks!
EDIT: grammar5
These sketch tools are still available, you just can't add them to the "solid modeling" toolbar (as they don't really have a function in this context). If you would like to edit the sketch toolbar, start a sketch and select a sketch plane (all the expected sketch tools should now be in the top bar), then right click on any tool and select "Customize toolbar..."
Let us know if this works!
Edit: Sorry for the bad info James. Thanks Jordan and Gaby!
EDIT: grammar
I've logged a Support Ticket for you.
