Multiplying variable in Dimension
neil_4neil_4 Member Posts: 3
I'm trying to define a dimension that uses two variables for instance i want the width of a box to be
width=#cubewidth*#numberofcubes
but it wont work.  Any ideas?
  • ilya_baranilya_baran Onshape Employees, Developers, HDM Posts: 1,255 image
    This is almost certainly a units issue -- #cubewidth should have length units, while #numberofcubes should be just a number.  Chances are that #numberofcubes ended up being a length, rather than a number, and so when you multiply it by #cubewidth you get an area (instead of a length).  Check the definition of #numberofcubes.  If that doesn't work, post a link to your document so that someone can take a look.
    #width = yada-yada
    Also might need some units depending on what the other variables are set to.
    OwS
    HWM-Water Ltd
