how to draw grooves and ridges
I have a cilindrical shape, in wich I want to draw a groove going all the way around. It is meant to fit an o-ring to make the cilinder seal inside a tube. I'm sure the solution is quite simple but I just can't figure it out. Any help? Added a picture link to clarify. https://imgur.com/rqARqvI
Twitter: @bradleysauln
https://drive.google.com/file/d/0B8aiSPm8RXu-bDZPN1hOR1ZDMTQ/view
(Sorry, didn't practice first so video is a bit dodgy! )
There are many ways to do this but if you're using a cylinder as your solid, as opposed to doing a revolve with the groove in the sketch, you can just do a simple revolve remove.
https://cad.onshape.com/documents/b17990734587253888b39dfa/v/fc69f294b3e7ef6402c6729c/e/cfbc4e78b7d5d61e4ca449e1
HWM-Water Ltd
