Converting Mesh To Solid
andrew_gesselandrew_gessel Member Posts: 2
Is there any way to convert a mesh to a solid? Thanks in advance!
  • grochinogrochino Moderator, Onshape Employees, User Group Leader Posts: 44 image
    Hi Andrew!
    When you import a mesh, you can reference it to create planes using the vertices of the mesh and then build sketches off of them, but Onshape currently does not convert this into a solid. Here's more information about what you can do with an imported mesh from our Help Page:
