Is Assembly export to STL coming soon?
mahmoud_2
Member Posts: 24 ✭✭
Hey,
I use export to STL quite extensively cause I use my 3D printer all the time. So I can export part studios, yet those are not very good when it comes to aligning things around!
I'm trying to print a fully working assembly out of the printer, so I need to get the mating done first and export to STL then print them...
What do you think?
What do you think?
scott_harris
Moderator, Onshape Employees, csevp Posts: 66
Hi Mahmoud,
We have exporting STL of an assembly on our enhancement list. In the mean time there is a work-around. It is not pretty, but you can export your assembly as an x_t file then import it (using the "+" in the lower left) to bring it in as a Part Studio. You can use "export to STL" on the Part Studio tab to get the all of parts as a single STL file. It is not the ideal solution but it works for now.
/ScottScott Harris / Onshape, Inc.5
/Scott
Good to know you have that on the list. I'mwaiting for it.
