Spline offsets seem to work, then don't
Maxpm
Maxpm Member Posts: 4 EDU
edited September 2017 in Community Support
I've used some splines to trace the outline of a logo.  I'd like to offset those splines to create a buffer around the outline.
When previewing the offset, the splines are shown to extend down and to the right until they intersect, which is what I want.  So far, so good.  However, when I confirm the offset:
...Onshape suddenly changes its mind.  What gives?
Interestingly, I can still extrude the outline as faces, and then use the Move Face or Thicken features on that.  But I'd like to stay within the sketch, if I can.
Test document:
https://cad.onshape.com/documents/bc5c64d7f767fe4cdb13b203/w/be4c0b50a8f320b4fc766bec/e/46a9710dccb2438db8e65fc1
  • mahir
    I can confirm this behavior. You can't even do anything with the geometry (like using Extend) untill deleting all relations, which makes it no longer an offset curve. Looks like a bug to me.
