Extrude problem: face of sketch only "extrudes" as a plane, not a solid (and not even then)
jascha_narveson
jascha_narveson Member Posts: 3 EDU
edited October 2017 in Community Support
A student of mine used Spline to trace the outline of Michael Jordan in his famous "Air Jordan" logo pose.  She used Spline correctly, and made an enclosed shape in her sketch, but was unable to extrude it - she could only get a raised plane, and not a solid, and the extrude would fail un clicking the confirm button.
I made a copy and played with it, and can't get it to extrude properly, either.  I'm attaching an annotated screenshot, in case anyone's interested to see what I'm talking about.
Any ideas?  Here's a link to the actual document - make a copy and try extruding if you can!
https://cad.onshape.com/documents/98641057b9267f77b57d8c80/w/f97d84d3ea685137a5096a7b/e/970d8473d275deb335125c07
cheers,
- jascha
  • elif
    elif Onshape Employees Posts: 54 image
    Hey jascha -
    This does look like a bug on our side. We would have to investigate further.
    The "raised plane" is the preview and not the result of the extrude, which as you said should've been a solid.
    I suspect something is not quite right with the spline. Sorry for the inconvenience.
  • jascha_narveson
    Hi, Elif -
    Yeah - further playing around revealed that if I segmented the shape using the Line Tool, I could extrude most of it save for the right hand and foot, so something's not quite right with the spline outline at those points, though I can't tell what it is...
    Thanks for the reply!
    cheers,
    j
