Conditional Features
Would be very handy to have the ability to use variables to control if a feature is defined or not.
A simple example would be the case where you want a chamfer on an edge of a plate only if the plate is above a certain thickness.
Howdy, have a look here:-
https://forum.onshape.com/discussion/comment/31990
You'll be pleasantly surprised
You might need to use the measure distance custom feature to crab hold of the dimension you want to use as your trigger.
Cheers,
Owen S.
HWM-Water Ltd
