Hole through sheet metal bend.
wayne_schaferwayne_schafer Member Posts: 3
In solidworks you can unfold a sheet metal leg and but a hole through the bend area and fold it back up. Can you put a hole through a sheet metal bend in onshape?
    Hi @wayne_schafer !
    As of right now, you can only make cuts that cut entirely through the bend (and all cuts are made against the folded model, not the flat):
    Please raise an improvement request from the 'Improvement request' section on the right -->
    to help us prioritize our work.
