Sheet metal/cardboard flange around corner
I'm not a sheet metal pro so there's probably a standard term for this kind of feature...
I'm trying to add a flange to sheet metal design which wraps around a corner and would be glued/riveted etc. to the perpendicular surface. This is something commonly seen in, say, cardboard box construction. I can kind of fake this with extrudes and revolved, but in that case the geometry isn't part of the sheet metal feature which it needs to be for drawings/cutting templates.
Attached image shows the fake version (dark blue, yellow) to give an idea of what I want to achieve. When trying to do this with a flange I believe it's intersecting with the other face which causes the flange feature to fail. I can also get pretty close by adding some move-face features to clear the corner area but it's prone to failure if I change any of the box dimensions.
https://cad.onshape.com/documents/2ceda000efc72144ae4ed89e/w/6cf6b9ac34a9edd2ef64ceca/e/deb7343e5618f6424fe6a4c9
I'd expect this to be stable with respect to sketch dimensions and extrude depth change.
