DXF Export
Will_SchleterWill_Schleter Member Posts: 9 EDU
The current DXF export creates polyline entities in the DXF file. Inkscape gives this error when trying to import:
ENTITIES of type POLYLINE encountered and ignored. Please try to convert to Release 13 format using QCad.
I realize this isn't necessarily an Onshape problem, but it would be nice if Onshape's DXF export gave an option to disable the use of polylines to create a more basic (dumber?) DXF file.
  • sebastian_glanznersebastian_glanzner Member, Developers Posts: 483 PRO
    Have you tried to export the dxf files in an older format? My supplier for laser parts always want the dxf files saved as 2010 version.
