form2 impresion with onshape bad configuration when exporting STL file?
franco_otaola
franco_otaola Member Posts: 23 ✭
it is almost sure that is a problem with the form2 but i tought about giving a try in onshape forum too.
hello,
i am beginning using the form2 and onshape too. i have donne two pieces here are the https://cad.onshape.com/documents/966ec463c87512c0b960ff76/w/bdd8da35f34c5b9131b19a5b/e/227273f8b1e8555876a021fb
 they are two pieces and i have exported (make the stl file) with the following configuration:
and the piece arrives to a point (when i am printing it) and stops making the pieces, the form2 continues working like if there is no problem and i at the end i find some material polimerised in the lower part of the resin container, i have tried two times and the two times it stoped the print in the same spot. for the configuration in the form2 i have put it for tought resin, in 0.05mm and i made a angle of 20º in the X also support density at maximun (it doesnt give me any red points in the file indicating that could break the piece at that spot). i dont understand what it is wrong in the pieces or configuration or if it is something else. and maybe someone in the forum is using this printer and at the same time had the same problem
thanks a lot
  • owen_sparks
    Hi.
    I've not used the custom resolution but just leave it in fine and have never had an stl that fails to print.  (I'm FFF though not SLA)  Have you tried this fine option?
    Cheers,
    Owen S
    HWM-Water Ltd
  • franco_otaola
    because the SLA have a finner resolution i have put the custom to change the  chordal tolerance to a smaller value that is why it is in custom. me neither but the thing is that the form2 is normally a really fiable machine and the two prints stopped at the same spot what is really strange....
    thanks either way
  • Jake_Rosenfeld
    Hi @franco_otaola ,
    I've used the form2 a couple times and also just set the resolution to 'fine' with no issues.
    Maybe @Jason_S can help.
