Interference Accounting in Onshape?
bill_woodbill_wood Member Posts: 12 ✭✭
Ok, thank you all in advance for putting up with my silly questions.
https://cad.onshape.com/documents/46bab87946ec082d60a3f35f/w/131d18edad74e21d209d11f6/e/326f8dc87fd409e461308bee
In this drawing a sphere has two perpendicular, aligned holes. An extruded rod is added to one hole using a slider mate. It slides perfectly. In reality, a second extruded rod could not be slid through the perpendicular hole, because the first extruded rod is physically blocking the hole....However, Onshape allows me to add a slider mate on the second as well, and create an impossible scenario.
Is this a downfall in Onshape? or is there a setting or procedure I am missing.
Thank you!!
Bill
  • sebastian_glanznersebastian_glanzner Member, Developers Posts: 482 PRO
    edited October 2017
    I think almost every CAD system would allow you to create parts which are interfering. The mates are not checking if there is a collision.
    This is something the user should check if it makes sense. But you are right, it would be nice if Onshape warns a user when there is a interference! You can easily see a collision by activation a section view.
    By the way you are missing some constraints in the first sketch. You could also reuse the center point of the sphere in the second sketch. And if you make a feature patter of the first hole, you can easily create the four holes in the sphere.
  • bill_woodbill_wood Member Posts: 12 ✭✭
    That makes a lot of sense @sebastian_glanzner. I just starting using OS recently, and am just in the learning stages...but it is nice to have so many helpful people in this forum. Thanks again, I will check into your suggestions.
